Extremely Low E36 Fuel Filter scraping issues
  • Extremely Low E36 Fuel Filter scraping issues
    My E36 sedan is pretty low (i think like 1-2 inches ground clearance at the lowest point)
    and I have gone through 2 fuel filter brackets, and 3 different fuel filters... for some odd reason the 328i and I think M3 models of the E36 run a gigantic fuel filter... and its location is extremely vulnerable to getting scraped...
    anyone got any tips as far as running a smaller fuel filter or relocating the fuel filter??
    - Scott
    Fuel filters on the M50s are located in the left side of the engine block, you should check on that
    AmberLamps..... Get rid of them!
      this.
      i had a 316i, that car had the filter under the body, near the frame rail.
      also had a 323i, (m52) tho never changed filter, but i think it was also located at the frame rail.
      and i have a 325i, (m50) has the filter on the block, under the intake mainfold.
      had some m50 blocks (320i etc) also had filters on the blocks.
      so i would recommend to, reloacte the filter.
      -Instagram@jdjurhuus
      Stretchsaurus and Pokemon.
        - Scott
        if you want to relocate the filter, do it. its incredibly simple.
        use google.
          fuel filter is very easy to relocate. oh and lower it
          cars and stuff
            I've seen many lower than you.
            Relocate the filter, I just googled it, and got like a million results...
            - Kielan (Key-lin)
              if this guy hasnt moved his, you are totally fine.
              now work on the low part.
                you could just make a skid plate
                  This guy is pretty damn low. You guys need to get off the internet and actually drive your "lower" cars
                    More pics of the car! Looks good
                      What wheels are those? they look sweet!
                      Instagram @vave_dirgo
                        Its low and smart but not extremley low
                          this made my morning haha
                            thank you haha, i drive this baby every single day... always drive with my buddies in the car...
                            EDIT: my front coils are as low as they can go anyways... probably lower the rear a bit more to get rid of the current rake.
                              i NEED to do this. I ripped the cover off it the other day. eeek.
                              -SW|UK-
                              Education - Knowledge - Power
                              insta: @stinkinrich
