sup fellas, i recently got ahold of some h&r coils and installed them yesterday. rear is sitting perfect but the fronts are sitting way too high. ive let them settle, and ive compared the height with a friend running the same setup and his are still not low enough for my liking. now i know the pros and cons of cutting coils so im not here to start an argument, what id like to know is if these coils seem to have a dead coil or where would be the proper place to cut. after studying the springs i think the bottom is where i would start and id probably cut off about half a coil but keep the flat bottom so it sits correctly on the adjuster.
i moved up from raceland coils and im really hoping i dont have to mismatch the h&r rears with the rl fronts but if thats what i gotta do to run at my desired height then so be it
ill take more pictures upon request, ill be removing them again off the car and see where i can go from there. tia
same spring setup:
same spring setup:
and i did run the rl spring until i realized the issue, i kept the h&r's though cuz i want the fronts stiff!
