I'm hoping this is the right place to be asking this, and I apologize in advance if that's not the case.
I have a 2002 C230 with the M111 engine. From the research I've done, I've gathered that MB uses the Eaton M45 S/C. I have also found that the M45 is used in the Mini S.
That being said, I have tried to get in contact with someone from Eaton without luck (yet). My question is this: would the aftermarket crank/underdrive pulleys advertised for the Mini S work in my C230? I'd assume that, since both cars use the M45, that the pulley applications would be more or less the same. Pulley kits advertised for the C230 are just obscenely expensive, and I've seen the ones for the Mini at a fraction of the cost.
Any hopeful information would be greatly appreciated.
Happy Thanksgiving everyone!
