Basically what the title says. Anyone know turbo kits or easy swaps into my car? Thanks in advance.
Looking for more power in my 635CSi.
Tubocharging Dynamics and Miller Performance both make turbo kits. Cartech, Callaway, and Dinan have all made turbo kits in the past as well, and they pop up on ebay from time to time.
M & S50/52s have been swapped in, though I wouldn't call it "easy." Search mye28.com for info on those swaps, as the e28 and e24 are basically the same car.
S50 swap, guy.Originally posted by NicMOSH View PostOh I forgot to mention.. My car has the full Split Second MAF upgrade and I'm unsure if it will effect my setup. I will most likely be going with a Stage 1 TD kit.If you havin' fitment problems I feel bad for you, son.
I got 99 problems but my stance ain't one.
celebrex pills
I have tried buy celebrex before and must say that brand cialis causes less side effects though. I had terrible headache with Viagra which made sex impossible sometimes. With cialis I forgot about it. I would recommend it to anybody who has similar problems and this drug is above all praises.”Last edited by Kotofey; 01-22-2012, 05:50 PM.
m30's are basically a factory turbo charged engine that bmw forgot to add a turbo to(besides the euro 745). Strong iron block, lower compression, prettty bullet proof internals. They are also plentiful. I would just put some upgraded head studs and head gasket and boost it till it blows up, then replace with another m30 for a few hundred bucks.
