Originally posted by HWY HNTR
View Post
Top Speed Governor Removal?
Yea i have the M104 (3.0 24 valve). It has great top end, starts to really pick up at about 2500-3000 rpm's and pulls all the way to 6500-7000 with ease. The cams make this cool whining sound almost like a little supercharger lol. But i know what you are talking about with the M103, my sister has an '89 300E. The difference between my car and hers is like night and day. And I am sure we have a lot of different drivetrain parts because of yours being graced with the lovely 3.6, but even your stock parts that went with your 3.2.1990 Mercedes 300CE- 24 valve
lol, I do this all the time, no effectOriginally posted by Michael Star View PostIf your car is an auto, something you might want to try.
Shift thru the gears manually. On some cars it will allow you to bypass the governor. Can't say it works for all cars, but you never know.
Conski, you don't happen to know your rear diff ration would you? Mine is either a 2.56 or 2.65, I had actually taken it out with the intentions of putting a diff from a c43 in there (still have it) but I decided I like the hwy better than off the line...plus I thought it was a lsd, but it's not
My differential has a ratio of 3.27, it switched over starting in '91 to a 3.06, but I don't have the first gear start like you do which sucks. What is the ratio for the c43 diff, is it lower than your current one?Originally posted by HWY HNTR View Postlol, I do this all the time, no effect
Conski, you don't happen to know your rear diff ration would you? Mine is either a 2.56 or 2.65, I had actually taken it out with the intentions of putting a diff from a c43 in there (still have it) but I decided I like the hwy better than off the line...plus I thought it was a lsd, but it's not1990 Mercedes 300CE- 24 valve
This...Originally posted by benz88 View Postswap in an LS1. problem solved.
I honestly dont understand why you would drive fast enough to remove it from a car unless the car is meant to be raced. How often do you want to drive over 130mph...? ESPECIALLY if the car is stanced. Ive had some pretty fast cars in my past and have gone 140 once, and realized it was pointless and dangerous.
I also don't understand why you need to remove the speed limited on a stanced car. Please enlighten us.StatusRacing.com
Configure YOUR Seat Here
Tel: 1.480.265.8600
Email: sales@statusracing.com
Fan us on Facebook
the AMG mercedes are limited to 155, mines limited to 130. My car has an AMG engine in it but I'm using the ecu out of the 3.2. I think I did a full write on my build thread.Originally posted by Angelic0- View Poston the other hand i thought the vmax governor was set to 155mph for every DTM car there is ?
except Porsches wich are limitless
Back when the mercedes was working I did rallies with it. So when I was on highways I always found it VERY annoying to hit my limiter. Yeah there was no point in it. But if you see no point in speeding then they should just put limiters for 80mph. I like speeding sorta. My car was low, but I was never worried about anything getting damaged, and it handled pretty good. Aside from some of the highways far up north and to the west, the southern highways are smooth as glass.Originally posted by StatusRacing View PostI also don't understand why you need to remove the speed limited on a stanced car. Please enlighten us.
