so my front ground control setup on my saab cannot go any lower on 300lbs 8" tall springs and its bottoming out pretty badly. Should I go with 7" at 430lbs or 6.5" at 550lbs? Give me some insight please
help with lowering and spring rates
I would start with shorter shocks get that thing from bottoming 0ut........
as for spring rate I would do 50 lbs increments......550 is way to stiff
as for height try a 7" with a spring rate of 400
no one can give you the answers kinda trial and error.....only you know what kind of ride you want
