I'm trying to decide what spring rates I should get for the swifts.
Most coilovers for the EP3/RSX have less stiff springs in the front. I cannot figure out why since the weight ratio is 61/39 and total weight is around 2700lbs, not to mention the power is all going to the front.
My instincts say:
F: Current: 10k 160mm --> 16k 120mm
R: Current: 12k 140mm--> 14k 120mm
The only reason I can work out that a less stiff spring in the front would be so the tires conform to uneven road surfaces better, is this true?
My instincts say:
