430 lbs Spring rate to high?
  • 430 lbs Spring rate to high?
    I have a 88 dodge omni. Front is lowered on a 1g neon struts (Shorter strut, oem neon springs. )
    Now i ordered my sleeves n everything.
    The oem spring rate is 90lbs.. But i ordered GC180.64.75 (7/2.5"/430 lbs) springs for the rear... Are these to high? My front is stiffer than before but i like it..
    1993 Mazda MX6 LS (Sold)
    1995 Eagle Talon TSi AWD (traded)
    1983 Porsche 944
    1988 Dodge Omni
    Knowing zero about the Omni, three things to consider. 1. So long as your system is adequately damped, you're good from a suspension control standpoint. 2. You might want to keep in mind the kind of forces a spring nearly 5x as stiff is going to put on your spring mounts. A soft spring does a good job absorbing shocks and transmitting force gently, which will no longer be the case. I know guys who run crazy spring rates on coilovers on the W124 chassis are beginning to see strut towers cracking, so just keep an eye on it, and finally, 3. a lot of the "feel" of a suspension comes from how stiff the rear is. It may wind up feeling pretty brutal, but whether that's alright or not boils down to your tolerance level.
    EDIT: One other thing. Stiffer rear springs are going to push the car toward more oversteer. Knowing how well Mopar products tend to handle in general, this probably isn't a terrible thing, but keep it in mind.
      Well its not going to be my track car. just my daily driver.
      1983 Porsche 944
      1988 Dodge Omni
        Might be a wee stiff on that light of a car then, but I'm a puss about stiff suspension.
        It also depends on the motion ratio of the suspension. Springs far inboard on the suspension can be a lot stiffer and not grind your kidneys into a pulp.
