sway bar link problem after e36 m3 coilovers installed? help
  • sway bar link problem after e36 m3 coilovers installed? help
    hey guys so today i installed my megan racing coilovers on my e36 m3, im also running racing dynamics sway bars and oem sway bar links, as i see those links are way 2 long because after the install of the coilovers was done, the ends of my sway bars hit the bottom of my control arms, I am aware that i need to order new end links, i spoke w ground control no luck since the shortest they make their adjustable links is oem size, I need something shorter so i contacted tuners and they have custon options of adjustable ones that go from 155mm min-170mm max. has anyone else ran into this problem and is there another company i could get the sway bar links from since turner motorsports is charging 155$
    IG- @NickyD_69
    photo by [url=https://www.flickr.com/people/77947560@N07/]
    You might be able to run the non-M3 front links if you drill a hole in the control arm for the stud on the bracket. Might need to look at a pic to see what I'm talking about but the non M ones are much shorter and attach to the control arm instead of the strut tube.
      you could use something like this?
      Find many great new & used options and get the best deals for Turnbuckle M10 Link. Adjustable from 120 mm to 160 mm at the best online prices at eBay UK! Free delivery for many products!
      so many variations of thread sizes and length. Hard wearing and cheap too.
      Float like a Cadillac, Sting like a Beemer!
      http://www.stanceworks.com/forums/showthread.php?t=24326
        thnxs guys i did research all night found some stuff, but i just went and ordered the turner ones yes they were 165$ shipped but i already spend 2000$ into suspension figured i shouldnt cheap out on the last part thnxs for the info tho....
        IG- @NickyD_69
