Hey guys,
I've been lurking around for quite some time while I work on getting my car dialed in.
I have a 2002 Honda Civic and am trying to lower it on my super ridiculously low budget...
Aftermarket coilovers aren't an option right now. Not even Rokkors or Racelands.
So I did a lot of research and came up with this idea:
The front struts use a cartridge type insert. The go-to replacement is Koni Yellows, as they're valved stiffer and shorter. Here's an installation of them:
I can't afford something like that right now. So I did some research and found these:
They're cartridges for a Nissan Stanza. I have a few other model numbers too.
They're all 1.75" in diameter and significantly shorter than the stock inserts.
The stock shock is about 2" in O.D., so I'm guessing the insert diameter is ~45mm
I was thinking I could just do everything like the Koni install but, instead, use the Monroe insert. I'll probably wrap it in duct tape to make up for the diameter difference (or metal sleeve). I don't know how to secure it, though; either set screws or the strut cap.
Does anyone think this is a bad idea? If you can point out any flaws (besides undervalved shocks), could you please do? I need some advice from guys who do this kind of work.
Thank you, Brian
Thank you, Brian
