hey, i have ground control coilovers on my e36 m3, and the front is plenty low, but i want the rear to get lower.
the Springs i have now are (6.5/2.5"/550 lbs)
i want a shorter spring in the rear to get lower. i kinda talked to Swift, who said they have "Z65-127-100" which is a 5inch spring, 2.5 diameter, but i am not sure about the rate, or what "100" means which they also call "10k" so i am not sure what the spring rate is, or what i should be using...
should i keep the same spring rate (550lb), or should i get a different spring rate.
(i only need an inch lower)
love
Mason
EDIT: 10 kg/mm = 560 lb/in
so should i keep the same spring rate?
love
,Mason
" - Stretchd8
" - FittedDownLow
