Im in a rut, my 1981 Toyota Corona Wagon and wanting Coilovers
I have no idea what the suspension setup is on the front of a Corona, but it might be worth a look into AE86 Corolla coilovers up front. As for the rears, you can simply get longer U-bolts and spacer blocks, that's how the mini truck guys have been doing it for years.
It's currently completely bottomed out on stock struts with no springs installed. The bumpstops are custom and they're about 1 1/2" shorter than stock.
For the front he is going to need much shorter struts and coilover sleeves if he wants to retain this ride height/go any lower. Front suspension setup is similar to an AE corolla and MX cressida in that the axle shaft and strut are a single unit.
Ideally he's looking for something to bolt in but I was always too cheap to purchase an off the shelf or readimade unit for this car.
As for the rear of the car, it's blocked over 5 1/2 inches. It's pretty retarded as it because you scrape u-bolt pretty often even though the car is nowhere near scraping subframe.
I loved this car, but all the modifications were free for me and I had dreams of doing it right when time/money caught up. It really just needs a minitruck style 4-link in the rear and to have some of the shelf weld-on coils similar to what a few people on the forum have had to do for e34s for the fronts.
But... He just doesn't really have the means to do this kind of balls-out fabrication (No offense, Jeff), so he's looking for something bolt-on or easily adaptable.
