Dgr Coilovers - 2012 focus
  • Dgr Coilovers - 2012 focus
    Hi there everyone. I have had some issues with my coilovers and cant seem to get them any lower. Maybe you all will have some suggestions for me. Here are some pictures.
    I have heard i can remove a ring and tighten up the spring some more but i am not so sure.
    also i was told to cut the foot of the coilover off and modify a new area to set the coilover back in. Bad thing that will void warranty.
    Now Dgr is sending me two new sets of springs but i do not know if that will make a difference in how much lower i can go.
    Any tips or tricks at all?
    you can remove those two middle orange lock rings for another 1/2". doesn't look like those coils are designed for much low, though.
    Does DGR offer shorter springs?
    025garage
      I believe so. I think he is sending me a shorter set of springs. I will be getting two new sets in the next weeek or two. Hopefully one of them will work.
        If you find out the inner diameter you can get shorter springs in any rate from Jaze (Jesus_Christ on the foums)
          I will have to get the specs and ask jaze when i get my new springs if they are not smaller. Hope they are. I knew the springs were the problem from the start. I love them for autocross but i really want my low for my new rims and look
            I'd get some new springs man. I'm sure you've seen Jon Holso's '12. He's using BC coils with some different springs.
            The coil design looks pretty close...
            from [FJ]
            Stock BC setup before I started messing with it
            Comparison of stock bc spring vs the shorted stiffer bc spring I ordered
            Finished product.....
            -spatakula
            (ノಠ益ಠ)ノ Y U NO LIKE SOLOAUTOMAG?!?!?!
              So luckily it's not me having this issue. alright i have been looking into different coils.
              Eibach sells some coil springs that are 2in ID, by 4 in tall, 350 weight.
              What i have now is 2 in. ID, by 7in. tall, 346 weight.
              Would make a big difference. Well thats a big help actually seeing that someone had to do the same thing. Plus always like the ride
                raise the springs and unlock the lowest collar. Then, spin the strut down.
                So i created this thread because ive always been getting questions on how to properly adjust these type of coilovers.. Many have incorectly adjusted the height on these coilovers so heres a thread for you n00bs, clueless ppl, and ppl who got their coilovers with out instruction manuals (like...
                R.I.P P.WALKER 2013/11/30
                  Well here is a Couple of pics of the old springs
                  What do you all think i should bring it down too???
