ok so i recently dropped my car on raceland ultimos and i love the ride, my problem lies within the rear adjust ability, the rear adjusters are maxed out and my rear is still really high. i was thinking about taking the rear adjusters out but thats only about a half inch. i see alot of e36s that are slammed to there nuts front and rear and i was wondering how thats possible. also another problem i have is that the rear sway bar end links are already rubbing the bottom spring seat =[ idk how to fix this.
E36 rear lowlow
Racelands aren't designed for low, and when you take them beyond what they were intended to do ( lower the car 60-80mm) the ride gets pretty brutal. Most people who are low have a some what custom set up, whether shorter springs or shorter bodies and RL's are full bodied with long springs. They do go low up front if you're willing to sacrifice comfort.
i had the same probably with my fk's last week so i took the adjuster/perches out. only took about 5 mins, did it by myself, and it made the rear sit much better. if you take them out and its too low then id suggest getting smaller springs or cutting a coil or 2 off. keep aware that ride comfort will be sacrificed, but thats all part of being low
Wrong, that is not all a part of being low.Originally posted by Drock11 View Posti had the same probably with my fk's last week so i took the adjuster/perches out. only took about 5 mins, did it by myself, and it made the rear sit much better. if you take them out and its too low then id suggest getting smaller springs or cutting a coil or 2 off. keep aware that ride comfort will be sacrificed, but thats all part of being low
Just get some quality coilovers and stop bouncing while you drive.
*edit; quality coilovers that are designed to go low. There are plenty of quality coilovers, most are meant to improve handling around a track. And not being lowered so much.
Tho there are coilovers that will get the car on the ground and still handle fairly well and not bounce.Last edited by Zic; 07-15-2012, 04:57 PM.-
Instagram@jdjurhuus
Stretchsaurus and Pokemon.
he has racelands. if he wants to be low the ride is gonna suck. i didn't mean that there aren't quality coilovers that go really low and still ride good. racelands aren't terrible if they're at a decent height.Originally posted by Zic View PostWrong, that is not all a part of being low.
actually my ride is very impressive i have ultimos not the regular racelands. i know these are ment to go lower then the originals because there a 1-4 inch drop. i still have about 1 1/2 of play in the front with plenty of rod stroke and clearance. im only wondering how to get the rear to go lower. thanks for all the ideas guys, much appreciated.E36 Bonnie
I facepalm'dOriginally posted by motocaddy View Posti quit reading when i saw raceland.
Yep! He has the mystery setup.Originally posted by got splits? View PostHeat your springs with a blow torch till they sag a bit.
Skrapez did it and his E36 road so well!
PM him about it I'm sure he'll help you out.
That's like saying "I own a Daewoo Lanos with A/C, not just a base Daewoo Lanos."Originally posted by royalife View Postactually my ride is very impressive i have ultimos not the regular racelands.BB6 Prelude . . E36 ///M3 . . VA WRX Limited . . 1969 Nova
Originally posted by OllieWe all love to turn heads. Sub-consciously we're all materialistic attention-craving dickheads.
