Hi all,
Having a problem here which I just can't solve.. Let me first give you some facts:
E30 316 from 1985, so it's a type 1. This weekend I installed coilovers from GAZ (from the UK). I've ordered the front struts pre-welded so I wouldn't need to weld by myself. At the back everything is totally ok, no problems. However, the front...
The coilover seem to be correctly installed.. Everything lines up perfect and all the bolts fit properly! My standard rims, which have the great sizes of 14inch, 6.5J and offset 30 will fit when the front is all up. I can't lower it to much otherwise the spring will hit the rim. No problem so far is what you think.
But then.. I've some Schmidt Modern Lines with sizes 16inch, 9J and offset 8. I've thousands examples of e30's running setups like this.. But given the fact that the original rims need spacers, I will never be able to fit the Schmidts!
As can be seen in the picture:
The 9J,offset 8 rim will always be a bit wider towards the coilover.. I will need a spacer of about 20mm (then it becomes on offset of about -12) to fit rims like these. Can't be good.. It's a ridiculous offset! As said before, there are so many examples of e30's running a setup like this.. I guess you guys know that
Anyone has an explanation? Anyone running GAZ coils?
Many thanks.
Many thanks.
Instagram@jdjurhuus
