Did you shorten the strut housing? if you didnt id imagine theyre the stock size
E30 Coilover options for budget ballin'
ya they got cut down about 2.5 inchs then we also cut down the spacer that goes in the tube as well. when it was all welded back up tossed the spacer in the tube then placed the strut in the tube and it was roughly 2/8's and inch lower than the very top of the strut tube so there is now way they are stock struts.....this is the reason you need to cut down the strut tubes to begin with.
I found G60 Koni's for 178 each shipped, so I might go with them. Unless I can find Bilsteins for a lot cheaper. I will call Jay at GC and figure out though.Originally posted by Stephen View PostYou can use g60 bilsteins. Id call GC about them, you need a weird gland nut.
On a related note, my coils came in today.
m42Originally posted by notloEnuf View Postwhat motor do you have?
I have just about the same pan clearance as you but I'm just barely tucking up front.
My m30 car's oil pan is a good inch and a half higher than the m42 one- It's higher than the steering rack. I had the FK's on that car but I blew the engine so they're on the 318is now.
then save and get the coilovers u want and not the ones u have to settle for.
