Car in question - MKV Rabbit
Coilover System - FK Street-Line Coil Over Kit
So, MkvFlipp and I decided we would go ahead and drop out his FK coilovers today to take the helpers and perches out, well we ran into some problems. When we had initially installed the system we ran the adjusters all the way down until they touched and left the helpers in. Now there is no way to get the adjusters moving at all! Took the coil apart, and even with the spanners could not get the adjuster to run up. PB Blaster, WD40, brake clean... nothing working.The bottom wont go down, the top wont go up. I am scared to heat the metal any due to the fact that they are gas filled!
Has anyone run into this problem?
I had thought of going through afcoracing to get some custom sized springs made
