Hey guys, been doing a ton of research but I'm about to bag my 2002 Jetta and I wanted to make sure everything with the setup I came up with is ok before I order.
This is my daily driver and I built this setup for reliability and price. Let me know what you think.
-air lift slam series front
-ss-5 w/ idf bracket rear (i hear lots of issues with air lift rears)
-4 way manual management (cheapest and most reliable)
-bilstein sport rear shocks (this way i can use my fk coils as back ups, just in case)
-air lift aluminum 4 gallon polished tank (would go with a 5 gallon, but a 4 will fill up even faster haha)
-dual 444c compressors (this way if one of the compressors dies, i can still air up)
-dual smc check valves (i hear standard viair check valves suck)
-dual compressor power kit
-dual needle gauge combo
-dual water trap kit
total: $2,252
i went with 444's over 380's because of fill time, 444's over 400's because it has a 33% duty cycle and only rated for 150 psi, and i didn't go with 480's because of price, same with ob2's.
main question: will my battery be able to handle the dual compressor setup? it's just a standard battery, not an optima or anything like that.
this is my car currently:
fk streetlines, pass. side frame notch, no fsb, few little odd ends here and there.
thank you for looking
total: $2,252
