Ok, I'm a complete noob to all things air.
I've been looking into running air ride on my 08' MINI. I've already picked up a set of Airrex struts, a 2 gallon tank and an iLevel interface (all 2nd hand from a forum member of another site).
I'm looking into buying an eLevel kit to control everything, however I have a few questions.
200psi? should I be looking at running the higher pressure as I'm only running a 2 gallon tank?
Compressors? If I am to run at 200psi, what size compressor/s would you recommend?
Hardlines? The car is a showcar, so a flashy install is on the cards. For that, I'd like hardlines between the compressors, tank and manifold. What's needed for a hardline install? I'm assuming the lines are copper or alloy?
Any other advice would be greatly appreciated.
