I have airlift struts on my 2011 wrx with the accuair elevel system. I had my car aligned at riding height. The issue im having now is the rear camber when I air out. My driver side is super sunk and my passenger side perfectly kisses the lip of the rim. Im not sure what my options are to have the rear look a little bit more even when Im aired out.
Alignment issues.
Whenever I get my cars aligned, I first set my camber myself. That way it airs out exactly how I want it every time. I don't care about the uneven tire wear at my ride height because of the camber but I do care about the toe completely wrecking my tires.Originally posted by infamous2119 View PostI have airlift struts on my 2011 wrx with the accuair elevel system. I had my car aligned at riding height. The issue im having now is the rear camber when I air out. My driver side is super sunk and my passenger side perfectly kisses the lip of the rim. Im not sure what my options are to have the rear look a little bit more even when Im aired out.
I tell the alignment shop to get my toe in line as much as possible without touching the camber. Negative camber will wear the inside of your tires more than the outside but if your toe is off, you're going to destroy your tires pretty quickly.
Camber and toe are relative but on most wheel setups, you can run plenty of negative camber and still get the toe in spec. The guys who run crazy wide wheels on their 350Zs for example, are basically sol because their camber is so far from the recommended oem spec that it makes it hard to get their toe in spec.
