So i am having a weird issue with my airlift suspension on my 07 Chrysler 300c SRT. I am running 2 airlift valves. 1 for each side of the car. So for some reason a little bit of air is staying in my rear bags even when i push the switch and it sounds like all the air is out. If i let the car sit over night it will drop all the way down in the rear or sometimes if i raise it all the way up then down it will go all the way down but if i start driving the car they will air up alittle but i dont hear the air going in the bags just raises slowly then if i park and try to drop it they wont go down all the way. Not even tucking the tire until i let it sit for hours or sometimes the up and down thing works. Im lost on this. I thought it was the valves but its only on the back and each valve has front and back for each side. I appriciate any help givin.
Issues with AirLift Suspension
Originally posted by Jrodsrt8 View PostSo i am having a weird issue with my airlift suspension on my 07 Chrysler 300c SRT. I am running 2 airlift valves. 1 for each side of the car. So for some reason a little bit of air is staying in my rear bags even when i push the switch and it sounds like all the air is out. If i let the car sit over night it will drop all the way down in the rear or sometimes if i raise it all the way up then down it will go all the way down but if i start driving the car they will air up alittle but i dont hear the air going in the bags just raises slowly then if i park and try to drop it they wont go down all the way. Not even tucking the tire until i let it sit for hours or sometimes the up and down thing works. Im lost on this. I thought it was the valves but its only on the back and each valve has front and back for each side. I appriciate any help givin.
