i have a vu4 set up and water trap between compressor and tank.. only 1 compressor.
Wheres the best place to put Check valves?
I agree with what's posted above. I always add a Check between the compressor and my water traps in case the trap leaks or is left loose. In somecases you may see checks installed between the tank and diaphragm valves. When installed there it prevents the fill valve from leaking back into the tank when the tank pressure drops below the bag pressure. This happens when there is a leak or when you are leveling a car with low tank pressure. VU4 manifolds don't require that.
Depends on what you are trying to do. Compressors already come with check valves installed on their leader lines although Viair's aren't the best. If you are trying to replace those, it is best to take off the current compressor check valve and install the new, upgraded one in place of it.
If you are trying to make your tank independent from the rest of your system, you can put a check valve on each supply line (between your tank and your manifold). This way, if you ever needed to do maintenance on your management, you can completely drain your tank/ take it out without airing your car out. Do not put check valves on the lines to the bags..
Originally posted by Rahstyles View Postif thats true then why did my bags leak out when my water trap broke.. which was between the compressor and tank?
I highly Doubt the Vu4 Holding air in all bags.. IM shure it needs some back pressure... IF you pumped your bags and took out the inline tubes to the vu4 im pretty shure the air will bleed out from the vu4 .. with no back pressure..
If im wrong please let me know..
Originally posted by Rahstyles View PostDont you need back pressure from the check valves to keep it closed? Also.. is it wise to put a check valve between tank and vu4 ?
Originally posted by NycCustomizer View PostCheck valves are spring loaded. No back pressure needed. VU4s dont need any pressure on the supply side to keep it closed so there's really no point to add one between tank and manifold.
Originally posted by Rahstyles View PostSo does that mean mine is malfunctioning?
