Bag over coils performance
  • Bag over coils performance
    So I have an evo x currently on stance ss+ coilovers and recently have been looking into bag over coil setups using my stance dampers.
    My main concern is I dont want to kill the performance handeling of my evo by switching over to bags, but my understanding is that depending on the psi you run in the bags it effectively creates a spring rate. So theoretically I could create a 10k 8k spring rate setup correct?
    Are they any downsides to this style of setup both for performance and lowering wise?
    I believe the accuair s4 runs this style setup which was what made me look into this.
    Any thoughts or things im overlooking would be greatly appreciated, thank you!
    If I understand correctly, you're planning on what the VIP guys call a "cup kit," where a small air cup sits above the spring on the coilover, allowing the vehicle to be raised an inch or two when desired, correct?
    Depending on PSI, the air cups will have a given instantaneous spring rate, but if my understanding of the physics is correct, you will only be able to subtract from the rate of your coil springs.
      No no lol, I mean replacing my springs on my stances with a set of universal air aero sport bags(or at least that style)
      So the bag will go directly around my damper replacing the spring in the coilover
        Gotcha. In that case, unless you drive with the bags at full extension (which you probably shouldn't), you actually won't have control over the pressure inside the bags. You see, the pressure inside the bag is a function of the weight of the vehicle and the dimensions of the bags themselves. At any point between slammed and maximum height, adding more air to the bags won't increase the pressure - instead, the vehicle will rise and the pressure will remain stable until the bag reaches maximum extension, at which point the vehicle will stop rising and the pressure in the bags will increase. It sounds counterintuitive, but that's the principle.
        In fact, all other things being equal, what controls the instantaneous spring rate of an air bag is actually the ratio between the fully-compressed height of the bag and the height of the bag when the vehicle is at ride height. The closer to fully-collapsed the bag is at ride height, the higher the effective spring rate will be. Unfortunately, this means that the stiffer the spring you need, the less uptravel you wind up with.
        Do keep in mind, however, that air springs are naturally progressive: the more they're compressed from ride height, the stiffer they get. You may find you do not need nearly as stiff an airbag as you would a comparable linear spring.
          So I could still get a desired spring rate if I got the right bag setup correct?
          Honestly up until very recently I would never have consider bags over my coilovers, but as I have been seeing, bags can be performance oriented and thats why they are attractive to me, especially the bag overs since I already have good dampers
            Depending on the spring rate you desire, you might be able to reach it with air bags. I can offer you the equation I use to calculate instantaneous spring rate for air bags if you want, but it does require some math.
            Otherwise, if you're looking for an extremely stiff setup, I don't think you're going to be able to achieve it with air bags. You can get pretty stiff depending on how much uptravel you require at ride height, but you're not going to see much beyond 1000 lb/in with any setup I can envision.
              We made an attempt at the studio to create a custom bag setup using coilovers dampened to 16k and our threaded billet bag sleeves we designed, and specifically sized bags in order to reach the desired spring rate at drive height, but we were never able to get anywhere near desired spec.. Wound up scrapping the project altogether
              Its a fine line between not enough air in the bag, and too much air in the bag. As stated above, it will take a bunch of engineering to get it all perfect. And from our past experience from bagged setups, if its not perfectly set up, the car will not drive like you want it to.
              1982 euro porsche 930 turbo
                Pretty depressing to hear that.
                So with that methodology, the Airlift STI and Accuair S4 both run a setup they put A LOT into developing for proper feel and performance. To the point where it would be near impossible to emulate on another chassis?
                Forgive me, but I really feel like its not quite that hard, as people have ideal psi's for driving around etc, I feel you could easily ascertain an ideal PSI for good handling. Obviously this all opinion and thought, as I dont have an air setup to test this with.
                  As Sam initially thought, why not just do an air'd topmount?
                  Best of both worlds with that setup.
                    I think you might be misunderstanding slightly. It's not that air isn't tunable for excellent performance - it absolutely is. I spent hours performing calculations on the design of the air ride setup for my Mercedes, and I am thus far extremely pleased with its performance. My goals were 300 lb/in at ride height, 200 lb/in at 90% extension, and 550 lb/in at low cruise. In all three cases, I have been able to hit within 10% of my targeted spring rate at ride heights that I'm pleased with.
                    What air is not good at is being extremely stiff. As I've alluded to above, there are two ways to make an air ride setup stiff as the dickens:
                    1. Drive around with the bags at max extension and just put a shitload of pressure in them, which is not sweet, because at full extension you have zero downtravel.
                    2. Since instantaneous spring rate of an air bag is inversely proportional to the ratio between bag volume at ride height and minimum bag volume, just set this ratio as low as possible. Essentially, this means you're driving almost aired-out. The obvious limitation of this is uptravel, which will be nonexistent. The non-obvious limitation of this is repeatability and upper range, as 1badg35 indicated. Since the spring rate is proportional to the negative cube of the linear extension of the bag, minor fluctuations in actual ride height can cause wild fluctuations in actual spring rate at the extreme end of the bag's compression.
                    To give you an example from my own vehicle, at ride height my front bags sit at 6" extension and have a spring rate of 320 lb/in. A half inch lower produces 374 lb/in and a half inch higher, 280. Ergo, if my eLevel controller doesn't quite peg my desired ride height and is off even by a half inch, my spring rate is still relatively close to my desired specs. Not that my eLevel system is that inaccurate mind you - it consistently nails my desired ride height, but this is a thought experiment.
                    Alright, let's continue our thought experiment. Say I wanted a stiffer ride and were willing to pay the price of limited uptravel. I now set up my bags such that ride height is at 4" of bag extension. My instantaneous spring rate is now 785 lb/in. Yet, a half inch higher and my rate drops all the way to 571 lb/in. And if my eLevel misses and goes a half inch lower, my rate is a whopping 1264 lb/in!
                    So, you see what's going on here? If you push a bag to offer an extremely stiff spring rate, you either wind up with zero downtravel (lame), or zero uptravel AND fairly unpredictable behavior (super lame). None of this is to say that a bag setup cannot be highly tuned –it absolutely can– but merely that air ride setups excel at a range of spring rates from soft to medium-stiff, and simply cannot easily reproduce the extreme stiffness that a metal coil spring can.
                      Okay, that was extremely helpful thank you!
                      However, I dont think you realize the spring rates arent as crazy as they seem.
                      320 lb/in is approx 5.7k
                      So for me to achieve an IDEAL 10k front setup, Id need to run 560 lb/in.
                      I dont think I need that stiff either. The standard 8k 6k setup commonly seen on many coil type suspension is 450lb/in.
                      So from what I can gather from what you said, that kind of stiffness shouldnt be too hard to obtain, correct?
                      Obviously an air spring is completely progressive, while a coil spring is linear(or that alteast try to be) and fluctuation will occur, but as long as you got the properly sized bag, I think a stiffer setup would be very obtainable.
                      Am I correct in this thought or am I still not getting something?
                        Air'd topmounts (like the muller air cup setup from Fortune Auto) isn't really good for driving around on, they are for temporary lifts, not for street driving.
                        My goal here is to have the ability of slammed parking status, but still be able to throw the car hard in corners like it was designed for. My evo currently I think is at a decent low for driving around. However its too low for hard driving.
                        On top of that when a properly setup bagged car drops to perfect fitment its just beautiful.
                          Aha! No, those are not as crazy of numbers as I had suspected. I wasn't sure what units you were specifying, and knowing some people run insanely stiff setups for stuff like drag use, I simply assumed you were talking in lb/in. My mistake! Amerocentrism at its finest
                          Alright, since we're back in the realm of reality, I thought I might share with you the equation I developed for calculating approximate instantaneous spring rate for an air bag setup. It is as follows:
                          where:
                          wc = the weight of the corner of the vehicle, measured in whatever units you want your result to be in (kg, n, lbs, whatever)
                          x1 = the height of the bag at ride height, again measured in whatever units you want the result to be in (in, mm, etc.)
                          x0 = the height of the bag when fully compressed.
                          d = the amount of deflection from ride height you're interested in measuring the spring rate at. This will give you an idea of how progressive your setup will be. For the spring rate at rest, insert zero. For the spring rate when compressed, set this number positive. For extended, negative.
                          This will spit out a spring rate in whatever units you feed into it, and this is the exact equation I used in the calculations above. For example, at ride height, my front bags sit at about 6" tall, and can compress to 2.7". Since we're interested in ride height, deflection is zero. Thus:
                          If I want to see how progressive my air bags are, I can add in the amount of deflection I'm interested in. Here, I'm interested in seeing how stiff the bags are when compressed 1":
                          This is obviously a simplified equation and the dynamics of a suspension system have more going on than the four variables that can be fed in here. Nevertheless, this should get you in the ballpark. Some hasty calculation on my part indicates that you are likely not to have a whole lot of uptravel when at ride height, simply because your vehicle weighs considerably less than my heavy pig of a car and you're looking for a much stiffer rate. Still, play around with the equation and see if you can get anywhere close to what you're looking for.
                            This was really bugging me, so I did some math based of 5 different starting pressures...
                            2.7" compressed
                            6.0" extended
                            4.3" stroke
                            (estimated, this should really be bag inside diameter) 4.5" diameter end cap = 15.896 in^2
                            15.896 in^2 x 4.3" = 68.35 in^3 = 1.12 L
                            PV = nRT
                            R = .08206
                            T = 295.372 K
                            psi to pascal:
                            10 psi = 68950 Pa
                            20 psi = 137900 Pa
                            30 psi = 206850 Pa
                            40 psi = 275800 Pa
                            50 psi = 344750 Pa
                            Moles of air:
                            (Pa x 1.12L)/(.08206 x 295.372) = number of moles
                            10 psi = 3186.042
                            20 psi = 6372.084
                            30 psi = 9558.126
                            40 psi = 12744.168
                            50 psi = 15930.210
                            corner weight 998 lbs over 4.5" diameter end cap = 62.783 psi
                            (not ideal, not applied over all area, doesn't account for bag flex or account for compressibility of air)
                            Add to...
                            10 psi + 72.783 psi = 501821 Pa
                            20 psi + 82.783 psi = 570769 Pa
                            30 psi + 92.783 psi = 639716 Pa
                            40 psi + 102.783 psi = 708664 Pa
                            50 psi + 112.783 psi = 777611 Pa
                            Volume of compressed air.
                            PV = nRT .... nRT/P = V
                            (3186.042 x .08206 x 295.372 K) / 501821 Pa = .154 L
                            (6372.084 x .08206 x 295.372 K) / 570769 Pa = .271 L
                            (9558.126 x .08206 x 295.372 K) / 639716 Pa = .362 L
                            (12744.168 x .08206 x 295.372 K) / 708664 Pa = .436 L
                            (15930.210 x .08206 x 295.372 K) / 777611 Pa = .497 L
                            Liters to cubic inches:
                            9.39 in^3
                            16.54 in^3
                            22.09 in^3
                            26.61 in^3
                            30.33 in^3
                            Divided by end cap area (15.896 in^2) = length
                            .591"
                            1.041"
                            1.390"
                            1.674"
                            1.908"
                            Subtract from bag stroke (4.3") for amount compressed:
                            3.709"
                            3.259"
                            2.910"
                            2.626"
                            2.392"
                            Instantaneous spring rate = corner weight (998 lbs) / amount compressed
                            10 psi = 269 in/lbs
                            20 psi = 306 in/lbs
                            30 psi = 343 in/lbs
                            40 psi = 380 in/lbs
                            50 psi = 417 in/lbs
                            Adding pressure will have a linear affect on instantaneous spring rate until the amount of force exerted exceeds the force applied. In this case it is 998lbs/15.896in^2 = 62.8 psi. Theoretically this would be maximum lift... force exerted equals force applied. This would be closer to the truth for an air cylinder, but the one huge issue is that the bag is flexible and changes shape/volume depending on height. It's impossible to accurately calculate the spring rate of a rubber air bag. My numbers are very, very rough estimates. The only way to do it right is with a spring dyno.
                            Sam, I assume your example numbers are based on your own setup. Would you be able to unload the bag which would have 998 lbs on it (jack the car up), air it up to 50 psi, measure the extended length, then lower the car and measure how much it compresses? I'm curious to see just how accurate my calculations are. It could also be done for 10, 20, 30, and 40 psi to check those too. If it's anywhere close, I would be glad to simplify the equation for others to use.
                              I'll get you those measurements as soon as possible. Right now, my Merc is back on coils until I can get my final bracket design finished (damn those Mercedes engineers for making the rear suspension on the W124 so damn claustrophobic!), so it might be a little bit of time.
                              I would like very much if we can devise a relatively straightforward solution to describe instantaneous spring rate on air bags in real-world application, rather than the purely theoretical approach I've outlined above. Obviously the dynamics of each individual suspension system will affect the real-world precision of any mathematical solution somewhat, but it seems like we ought to be able to come up with something here.
