Introducing the Zaetech DigiGauge Pressure Display
  • Introducing the Zaetech DigiGauge Pressure Display
    ZAETECH DIGIGAUGE PRESSURE DISPLAY
    Have you ever thought about replacing your basic analog gauges with a clean digital display? Maybe you were deterred by the lack of a plug and play kit, or perhaps the lack of screen color options was a turnoff since it wouldn't match the interior you've spent so much time on.
    As a stand-alone digital pressure gauge, or as an accessory to Zaetech’s flagship product TouchBox, DigiGauge is the perfect accessory to accurately monitor the pressures of any air suspension setup. DigiGauge features a crisp, digital LCD screen with color backlighting for displaying four corner bag and reservoir (tank) pressure.
    Optionally, the user can pair the DigiGauge unit with a Zaetech TouchBox and view bag and reservoir pressures directly on their iPhone or Android (coming soon) Smart Phone. DigiGauge is truly the next step in minimalistic digital air ride pressure display systems.
    Features:
    • Compatible with any Air Ride System
    • Four Corner (Bag) and Reservoir (Tank) Read-out
    • Five Screen Color options
    • Black Anodized Aluminum Display
    • 0-200psi Pressure Readings with 1psi Resolution
    • Simple ‘Plug-n-Play’ Installation
    • Integration with TouchBox Wireless Controller
    • Free Technical Support
    Includes:
    • DigiGauge ECU
    • Full Plug-n-Play Wire Harness
    • (5) 200psi Digital Pressure Sensors
    • Black Anodized Aluminum LCD Display Screen
    • 25ft Display Harness
    DigiGauge is available exclusively through www.bagriders.com for $299.00.
    Most impressed by the slim pressure senders. Will definitely be picking one of these up this winter.
    2003 A4 3.0 Quattro 6MT | Accuair | Airlift | Alpine | EuroGear | Hertz | Kenwood | Milltek | Southbend | Unitronic | Valeo
    iG @207carney
      Where is the best place to mount the sensors? I assume close to the bag is better, but will they work if mounted close to the manifold in the trunk?
      '18 BMW F80 M3 San Marino blue / Amaro brown
      instagram.com/frodedale
        Your best bet would be to mount the sensors off of the 1/4" gauge ports on the back side of your manifold. You will need to get (4) 1/4"-1/8" reducer bushings.
        As for the tank pressure sensor, you can either put it on the tank or you can put it in line from the tank to the manifold using a digital gauge tee.
          Perfect! I don't really want to pull more cables out from the trunk.
          I'll have to order this soon. The display fits nicely in the compartment where the sigarette lighter is.
            That's where I put mine! (I don't have pictures though, nor do I have the car at the moment)
              Here are photos of the other color options:
