duel 33% or constant duty cycle compressors
  • duel 33% or constant duty cycle compressors
    Would dual 33% duty cycle compressors be enough or would one constant duty cycle compressor work better?
    what pressure you planing on running to? Im guessing you're going for dual 400c?
    if you're only going to 150psi then they will be fine.
    Originally posted by anth
      Yep that's exactly what I'm planning. Thanks
        just remember, being 33% they can only run for a little while before they overheat. If you can afford it, I'd pick up some viair 444c... Thats what I run and they are 100%duty and have a higher cfm than most 100%duty comps.
          Yeah I think I'm going to go that route. Keep every option covered unless a line breaks. The Viair 450c is what they sell now for their constant but it sounds the same as the 444c
            444c dual pack is the best.
            Mr. Belvedere
