First post and I have a couple of questions...My 1995 eldorado's front struts are dying...I have 2 choices on the swap...go with a factory type replacement strut with the universal strut bag over it....or go with one of the pre-made air bag strut that either drop into mmy hacked old strut or come with the brackets and tabs already welded on...for someone that can cut and weld fine, and had build a few different suspension setups from jacked up to slammed back in the day...which would be the better route to go? cost and end result....
As far as an air management setup....how good or crappy are the viair double compressor with the 7 or 9 switch setups that are running around 6-7 hundred bucks, on ebay??? thanks, John Pikeville KY
