whats the diffrence if i just put my aerosport bag on my mac strut or if i put the bag on the strut with a coilover?
bag or coil over
Are you trying to figure out the difference of putting an Aero Sport on your stock suspension vs a coil over? If so, in most cases your best bet would be to use a coil over since the struts are designed to be low. The oem suspension will work with a bag over coil setup on some cars but it will ride horrible on others since the suspension wasn't designed to go low. What kind of car are you looking to bag?
the issue that you would possibly run into with the stock struts is the position of the bag. You may not be able to get the bag into a low enough position to get the car as low as you would like.Originally posted by plyrh8r1 View Postim bagging a 1993 ford escort.
The other issue is that the stock struts may bottom out before the bag is completely aired out limiting how low you can go.
So its not that you cant do it it is easily done with stock struts the issue is that the results may not be to your liking.
Yeah I don't really think your stock struts will be good for a bag over coil system. Like Matt said, you're probably not going to be able to get the car low enough.
I would go with the Air Lift universal builder kits and make your own air struts. It's really the best way to go about it when no one makes air struts for your car.
