Who makes a kit, so far i have found airrex and airrunner, is there any other options out there
Air ride for a Q45
Tags: None
i just need struts or a strut bag combo. im going to be running accuair. but i want to be able to lay on the ground or as close as i can get//// www.loweredclass.com \\\\
cause that wont go low enough it will bottom out on the strut before it gets to where i want it to sit.Originally posted by xseveredveganx View PostIf you're looking for struts that aren't already on your car, a junkyard would be your best bet.
Why not just weld on the UAS brackets onto your current struts? If the struts are blown, you can get new cartridge inserts from Infiniti.//// www.loweredclass.com \\\\
s13 suspension swap with coils and uas is the best way if you wanna be on frame rails.Originally posted by Amoney47 View Posti just need struts or a strut bag combo. im going to be running accuair. but i want to be able to lay on the ground or as close as i can get
not the same body, but same chassis, on the ground, and thats what i did
Disclaimer:
I am rude, opinionated, and sometimes come off as a dick. I am just speaking my mind. If it offends you, PM me. Don't go whine to someone else. I am civil, talk to me, just dont be stupid.
and USE THE SEARCH BUTTON
