Circuit breaker or fuses?
This topic is closed.
  • Circuit breaker or fuses?
    Is it okay to just run one 100amp circuit breaker between the battery and relays/compressors?
    I’m installing two compressors with two relays and 5 gal. tank.
    Or do I have to use fuses between each compressor?
    If your using AirLift, they require a Secondary Compressor Harness. It gives a signal to the controller and has a separate fused power harness.
    ☆ ☆ ☆ AIMGAIN Lexus IS300 AWD ☆ ☆ ☆
    · AIMGAIN JUN VIP EXE Type-2 Aero Under Spoiler Kit
    · AIMGAIN GV-S Wheels F19x9 +32 / R19x10 +4719
    · AirLift Performance 3P Air Suspension with Dual Compressors
