I need help wiring my Z.....I can take a few pictures. I'm trying to figure out which lines connect to each other. And I have a solinoid block with 2 supply's in and 2 outs. I only have 1 line from the tank. Do I need to block those off with brass fittings?
Air Suspension ecu/relay/wiring setup
This topic is closed.
Try their manual, if you are not using any port on a tank it should be blocked.
Helpful ansOriginally posted by Dohcser View PostTry their manual, if you are not using any port on a tank it should be blocked.
https://accuair.com/sites/default/fi...20Target_1.pdf
