Hello,
Ok, so I'm having a leaking issue on my setup. I'm using AirForce Suspension struts on my 04 TSX paired with Airlift 3P. After the install we noticed the front drivers side corner dropped about 5psi every 30seconds or so. We immediately sprayed everything, bag, lines, fittings, manifold etc. No luck. The next thing we did was reverse the lines on the manifold. So the line from the front driver bag was put into the front passenger port on the manifold. What happened next surprised me. The drivers side corner that was leaking before completely stopped leaking, however the passenger side front began to leak when it had not been before, which leads me to believe its an internal leak in the manifold itself. Well, this is the 3rd manifold they've sent me and I'm having the same issue. The lines were cut with the cutter provided with the kit btw. I'm really wanting this to be an install error but I can't seem to justify that.
Any suggestions?
Any suggestions?
