problem solved.
kill switch help!!
This topic is closed.
iLevel goes into a standby mode after 24 hours, and should not drain your battery. A kill switch should not be necessary.
If you're intent on running a kill switch for your management, a standard SPST toggle triggering a relay on the red wire from the battery to the e-Level ECU will remove all power from the system.Last edited by Oh Damn, it's Sam; 09-12-2015, 01:51 PM.
lol thx for the editOriginally posted by Oh Damn, it's Sam View PostiLevel goes into a standby mode after 24 hours, and should not drain your battery. A kill switch should not be necessary.
