hi, i would like some help with a hardline setup for my golf mk6 , I will only have hardlines in the trunk and then ordinary plastic tubing under the floor of the trunk . my problem is that I do not know where I can buy stainless steel pipe or fittings.
Then I dont know what sizes the pipe will have on the inside and the outside( dimensions) I run 2x viair 444c and autopilot v2 with 1/4" connections.
what I need (what I think) is : 10 foot stainless steel tube that fits 1/4 " connectors on the valve package , compressors , and the tank. I also need the fittings between the stainless steel pipe from the valve package to the usual plastic pipes under the floor (4 pieces ) and also between the compressor and tank and from the tank o the valve package. I am using Google Translate and my bad English, but I hope you can understand what I mean. Best regards
[/IMG]
