Hello folks,
I'm having an issue with my front 2 bags not inflating. The system (air ride technologies) is about 2 years old and was working fine up until about 2 months ago. The rear bags inflate and deflate without a problem but for some reason the fronts are no longer getting enough pressure to bring the car off the ground.
When I go to inflate the front bags they seem to take air for about 3 seconds and then once there is pressure in the system it no longer wants to inflate. It seems to release the little air pressure that is built up for that 3 seconds without a problem. Since the rears work flawlessly, I swapped the plungers and coils with the front ones and that doesn't seem to be the issue. Rears still work, fronts still will not fully inflate. I've also hit all the connections with soapy water and there are no leaks.
Any advice on what I should try next?
Much appreciated!
Much appreciated!
