Hi Guys...
Have a 1995 E34 525i that I plan on bagging in the next year but i'm more interested in a performance/handling-oriented setup and was thinking about the valves. Most people use a valve manifold like the AccuAir VU4 that is mounted somewhere in the trunk, etc. However, depending on where it is mounted, the length of air lines from the manifold to each airbag could be different lengths and theoretically, different air volumes. Since the "spring rate" provided by air springs is a function of the air volume and air pressure, would the differences in air volume created by different lengths of air lines to each bag make any difference? Would there be any benefit to running individual valves at each corner of the car (well, 2 valves really...1 fill, 1 dump) so that the length of hoses could be equalized and minimized? From a handling/performance standpoint would there be any benefit of doing this or is it a moot point? Curious on your thoughts...Thanks.
Alvin Caragay
Shop Manager
ARC Automotive, Inc.
arcautomotive.com.ph
Alvin Caragay
Shop Manager
