Subwoofer with air ride
This topic is closed.
  • Subwoofer with air ride
    I am about to install an eLevel kit in my MK4 Golf.
    I have a question about how I would wire up the air management and still be able to keep my subwoofer and amp. I'll be using a Stinger 80amp relay.
    What do I need to do in order to power both the amplifier and management?
    I believe the amplifier is a 1000w peak Kenwood to a 12" sub.
    Compressor is a 444c.
    Instagram: dongalong
    I'm confused, what are you using the relay for, to kick on the compressor? You don't need that much relay for a 444c.
      He is correct. A 444c only has a draw of 38amps, but with that being said, you will be perfectly fine running an 80amp relay, especially if you plan to install a second compressor later on. Which part of the wiring are you confused with? As long as you wire up the systems as two separate systems then you should be perfectly fine.
        Hey Shea! This is Derek. The one Mikey is installing the eLevel system for.
        Basically I'm confused about how to wire both from the single power wire connected to the battery.
          Get a power distribution block.
          Bagged Kia Forte 5 Build HERE
            Thanks! That's what I just ordered.
              what block did you order, I have a feeling I am going to need to do the same thing
                This one:
                http://www.sonicelectronix.com/item_...y-Scosche.html
