is it safe
  • is it safe
    Read a lot of forums and comments, just wanted y'all's 2c. a mockup for deleting leader lines, heard lines will "get too hot" and melt the plastic, and a ton of people who say its perfectly same to run, lemme know.
    flaming and calling me stupid encouraged
    @DollaDollaDill
    Picture is hard to see, but I wouldn't be worried unless you actually have plastic touching the compressor itself. The leader line gets hot, but I doubt it gets hot enough to melt plastic.
    2008 Acura TL Type-S, Accuair Equipped
    Follow me on Instagram: @ebelp
      First I was wondering why you are deleting the leader hose?
      If you are set on going without a leader hose why not get rid of the plastic DOT tubing and just use brass fittings instead? Are you going to be installing a check valve downstream? Will you be mounting the compressor in a position that puts the trap verically?
        A couple of thoughts:
        1. You need a check valve somewhere in there - the check valve off the Viair leader hose is fine, but you've got to have one or the compressor simply won't compress.
        2. If heat does become a problem, a 1" section of copper or aluminum hardline can't cost more than a nickel.
        3. The closer your water separator is to your compressor, the warmer the air going into it. The warmer the air, the less effective your water separator will be. It's not a big deal, and I probably wouldn't worry about it (mine's close too), but it's something to consider.
