I have a question regarding the elevel. Since you dont need pressure gauges to monitor the bags, will the elevel system automatically stop inflating at max psi if you air up manually? I think 125psi is the max each bag can hold. So if i aired up manually with the touchpad will it stop inflating past 125 psi.
Also with the new updated elevel sensors. Does each corner have to use the same mounting hole in order for the readings to be correct. For example lets say i mounted the sensor on the last hole at 4" travel then another corner on a whole with 2" travel. Will it throw off my readings?
