How to plumb this?
  • How to plumb this?
    Bought a used air ride kit that the people knew nothing off they took it off a car they bought. It's two long double valves with four holes on it but two of them are blocked off. Idk but it appears I can run all four corners off just this. Any ideas?
    4 valves. Two lifts two dumps. The center line is the source. The top two feed the bags the bottom two are the dumps. It all depends on if you want a 4 or 8 valve system.
    Originally posted by Kielan
    I've had a lot more fun in my Dad's Prius than I care to admit.
    BMW e23 build Thread
      Well there are 5 ports per side thats what is confusing me. Two are open one has the feed line into it and then two are blocked off on each "side" That is whats confusing me.
        where is the fifth port? i only see 4 per manifold.
          Updated the first post
