So I was wondering where to post this up, but because I want to share some info about the tires I used and its stretch, decided to post it up here.
I came across a rare set of BBS Impul couple of weeks ago.
Re-drilled them to 5x100 (so now dual bolt pattern) and fully polished by Goldmember (xB with Burberry interior).
Anthony's Hellaflush BBS RS equipped xB
So here is a pic of my new wheel(s). BBS Impul.
Specs:
18x9 +25(F) & 18x10 +40(R)
Here are some pics that I took yesterday without the lip kit. Just found out my passenger wheel was hitting the chassis so metal on metal :/
The driver rear wheel is bent a little so i gotta get that fixed asap.
Thinking if I should change all the bolts to Gold
Anyways, so I went with a tire brand called Achilles. Did some thorough research and found out these tires are used for drifting and a better quality than nankangs. (Did some google searching).
The stretch on these tires are amazing! I literally can go a size down. 18x10 is wrapped on 225/40/18 and 18x9 on 215/40/18. The rears came out very nicely but for the fronts, there is a stretch but the lips are barely noticeable.
Pic of 215/40/18 wrapped on a 18x9
Hope this info about the tire helped out some of you guys
Specs:
