195-45-15 toyo t1-r
The Tire Fitment Database
This is a sticky topic.
215/40-17 Falken ZIEX ZE-912 on 9,5x17.
I know it's miles between the outer lip and wheel arch! Will be fitted with a 1" wider lip, so they become 10,5x17. Think that will be perfect.
Can't cheat by using spacers!
Don't mind about the soap-bubbles. It was leaking air, and I needed to find out where. It's fixed now.
hey. i also drive a mkv rabbitOriginally posted by Horhey1220 View PostHey guys drive a Vw mk5 rabbit going 18x8.5 up front 45 et and considering 18x9.5 33et in the rear.. What tire size should I run for a good amount of stretch and what brand and model.. Do u guys recommend the size wheel in the back or should I keep in 8.5" all around
and im fixing to put on some merc wheels 18x8.5 et28 front and 18x9.5 et33 rear. for tires im going with nitto neogens 205/40/18 front and 215/40/18 rear via recommendations from friends. ill take a couple of pics and post them for you when they get mounted.
interested in the old question...
how to solve air leaks in 215 40 18 on a 10?
is anyone have any issue on nankang / t1r??
I'd like to have some flush result (if it's possible).Thanks in advance.
Instagram@jdjurhuus
