195-45-15 toyo t1-r
The Tire Fitment Database
	This is a sticky topic.
 215/40-17 Falken ZIEX ZE-912 on 9,5x17.
 I know it's miles between the outer lip and wheel arch! Will be fitted with a 1" wider lip, so they become 10,5x17. Think that will be perfect.
 Can't cheat by using spacers!
 Don't mind about the soap-bubbles. It was leaking air, and I needed to find out where. It's fixed now.
 hey. i also drive a mkv rabbitOriginally posted by Horhey1220 View PostHey guys drive a Vw mk5 rabbit going 18x8.5 up front 45 et and considering 18x9.5 33et in the rear.. What tire size should I run for a good amount of stretch and what brand and model.. Do u guys recommend the size wheel in the back or should I keep in 8.5" all around and im fixing to put on some merc wheels 18x8.5 et28 front and 18x9.5 et33 rear. for tires im going with nitto neogens 205/40/18 front and 215/40/18 rear via recommendations from friends. ill take a couple of pics and post them for you when they get mounted. and im fixing to put on some merc wheels 18x8.5 et28 front and 18x9.5 et33 rear. for tires im going with nitto neogens 205/40/18 front and 215/40/18 rear via recommendations from friends. ill take a couple of pics and post them for you when they get mounted.
 interested in the old question...
 how to solve air leaks in 215 40 18 on a 10?
 is anyone have any issue on nankang / t1r??
 I'd like to have some flush result (if it's possible).Thanks in advance.
						 Instagram@jdjurhuus
Instagram@jdjurhuus
