What widths & offsets are you all running? I want some ideas for my lady's touring please and thanks.
Yo e46 d00dz!
Tags: None
Haha, I should have been more specific. I wanted info on people's non-stock setups to see what has been stuffed inside their fenders... better?Originally posted by M.Burroughs View PostE46s and E36s share the same offset range.
Much appreciated.Originally posted by Nightfox.Technologies View PostBut we're here to help, so let us know what you come up with!
Thanks for clarifying. That was about all I wanted to know. She has a few BMW wheels in mind but want to make sure what would "fit" with the proper lowering devices.Originally posted by M.Burroughs View PostWell, I wasn't meaning search so much as what e36 guys are running should fit damn near the same.
The most common "presets" are 17x8 et20 (not aggressive), 17x8.5 et13, 17x9 et20, 17x10 et20 (out back).
Mind you that she wants her Touring to have a nice stance, but nothing too crazy...
Those offsets will cause the touring to rub unless you roll the fenders, have stock suspension, or are running fairly stretched tires. With an 8.5" or larger width, you might want to stick closer to et3X to prevent rubbing on stock fenders.Originally posted by ignacio View PostMuch appreciated.
Mind you that she wants her Touring to have a nice stance, but nothing too crazy...-David
active autowerke | e46non.com | nitto-tire | dtm-spec.net | precision-sport.com
Regardless of offest, coilovers will be used.Originally posted by Rtistik View PostMight want to keep the widths/offsets a little less aggressive then, otherwise you're going to need to go low and start getting "crazy"
Thanks for your input. Off topic but I think we met at a CFBMW meet... I had the Montreal Blue e36 with the plaid headliner. Have you been to any more meets since then?Originally posted by activ3 View PostThose offsets will cause the touring to rub unless you roll the fenders, have stock suspension, or are running fairly stretched tires. With an 8.5" or larger width, you might want to stick closer to et3X to prevent rubbing on stock fenders.
yeah I remember you! I'm actually in south florida until mid august when I move back up for school. I usually hit up the cfbmw meets a few times per month, but haven't been active this summer since I've been away..Originally posted by ignacio View PostRegardless of offest, coilovers will be used.
Thanks for your input. Off topic but I think we met at a CFBMW meet... I had the Montreal Blue e36 with the plaid headliner. Have you been to any more meets since then?-David
Right on, yeah I can never find the team to get out to the meets...Originally posted by activ3 View Postyeah I remember you! I'm actually in south florida until mid august when I move back up for school. I usually hit up the cfbmw meets a few times per month, but haven't been active this summer since I've been away..
E46 touring inspiration :
