Hi,
So i had wheelflip drill some custom barrels/ lips for my hamann pg3 wheels. He sent them back but said he recommends i weld the rim halves together. he mentioned the center register and the low bolt count. Pg3 have 30 bolts
What are your thoughts? this is my first set of 3pc wheels so i have nothing to compare them to. the centers do have a register:
Here is the other issue:
The factory bolts are titanium $$, and are not sold anymore, havent seen any on ebay ever.
20 of the 30 are slightly to short. To fully thread the nut, it needs 5.5 full turns, and im getting 4.5 full turns when i torque them. This applies to the 20 through bolts, the other 10 are exactly the right length since Hamann has thick washer of the 10 that go into the center from the back side, with a thinner washer, they get the same depth as before.
I see options are :
A. mill the halves down about 0.02" each $$
B. buy steel, non OEM style bolts $$
C Counter sink the holes 0.04" or so (worst option)
D Do nothing
I want to get these done though, they look really good and are exactly the right offset!
I see options are :
D Do nothing
