I'm thinking of buying my mates 36 and I been offered some rondell mesh wheels in 8&10x17 but the 10 got et 15 the question is will this wheel fit or will I need lots of arch work ?
e36 help!
IIRC the rear has bolts to adjust the camber, the front you need camber plates. et15 will fit in the rear with a roll, wont need a pull, but you may have to cut the fenders to get the rear flat enough to not rub since the rear fender lip is rather thick. This is all assuming you put some stretch on them.
whats the front offset?
ig: @jonnie86
This with 215 40s, but they will poke alot, 10 wide et15 rears are very agressive for the e36Originally posted by Tuck&Poke View PostIIRC the rear has bolts to adjust the camber, the front you need camber plates. et15 will fit in the rear with a roll, wont need a pull, but you may have to cut the fenders to get the rear flat enough to not rub since the rear fender lip is rather thick. This is all assuming you put some stretch on them.
AmberLamps..... Get rid of them!
indeed, its agressive, with a pull he might be able to get away with a 225/40. I just helped finish a setup with a 10 +10, no pull, just cut and rolled fenders, 215/40Originally posted by cabezzz View PostThis with 215 40s, but they will poke alot, 10 wide et15 rears are very agressive for the e36
ig: @jonnie86
Instagram@jdjurhuus
