Hey guys,
So I'm refinishing my OZ Mitos on my E36 and I'm stuck on the second wheel. So I've bought brand new 3 inch lips and I've had the center pieces powder coated.
So here's the problem, as I'm trying to place the center on the lip the center will not sit flush on the outer lip. This causes a problem, where the bolts will not go all the way through the face and therefore I can not bolt the wheels back together. I'm thinking the powder coats didn't tape off the inside of the center pieces and added so much extra material that it's making for an extremely tight fit.
But here's the thing, I've managed to put one wheel together and seal up successfully, but I had to tight the bolts one by one to force fit the pieces together slowly until it was flush. Most likely not a smart idea.
Hopefully that makes sense and someone can hopefully chime in.
Thanks guys!
-Josh
Thanks guys!
-Josh
Instagram@jdjurhuus
