Hi I need some help.
I'm. In the process of slamming my Daihatsu sirion 4trak.
I've got some PCD adaptors which are not hub centric.
They change the stock 4x100 to 4x114.7 for my 1976 appliance industries mags.
The PCD adaptor uses a spigot ring as the center bore is raised from 54.1 to 67.1
The problem is that after the PCD adaptor is fitted there is no more hub for the rim to sit on.
I am currently running the stock tyres as this is my daily. I will be getting the new rear struts for the car soon as PB Brakes sent the wrong ones. The wheels will be ready to bolt on by then. I need advice in whether to purchase new parts or whether it will be safe enough to just bolt the wheel unto the adaptors with nothing in the center as support.
Thanks in advance.
Il post a build thread as soon as I'm done.
Thanks in advance.
