Hello,
I just made my first attempt at polishing some lips on a wheel build i'm doing at the moment.
I bought the lips second hand and they had a few light scratches, and some damage from mounting tires.
I wet sanded 600/800/1000/2000 grit wrapped around a sponge as an improv sanding block, and then went over with mothers mag/aluminum polish.
It came out decent, but the finish still has noticable scratches in certain lighting.
My question is, are these scratches due to improper technique, or are are they just due to not buffing with a proper buffing wheel and compound after sanding?
Any help is appreciated! I'm just trying to see if I should redo the sanding process, or go ahead and invest in some decent buffing tools.
Here's some pictures I took along the way.
