Just needing a little help please seen some wheels I want in 19" sizes are 19"rears 10.5 wide fronts 19" 8.5 or 9.5 what's the best and best ET I think the rear are et 22
It's for bmw e46 m3 : thanks
The 10.5 et22 rears should fit fine with a 255 wide tire. I ran an 8.5 et13 on mine, which pokes about the same as a 9.5 et22. You'll definitely need to add camber and/or roll the fenders. I swapped the strut mounts to get about -2 degrees, and the fit was ok... still poked a little too much for my taste.
