Ok Im getting wound up here. I dont know if I have been mislead and am using false terminology or if people just arent on the same page.
Ok, so I want to keep my bolt pattern but get 30mm spacers which would require a spacer with studs that are pressed in.
I call these spacers cause I am not changing the bolt pattern to adapt a new bolt pattern but I see some people referring to them as adapters cause they have studs regardless.
This is causing confusion with orders I am placing now with two different companies.
I told one guy ( sounds cool ) I can source the hardware myself but he still ask about extended lugs which made me think it would be a standard shaped spacer with no pressed studs and only 5 holes. I said I want a set that has 10 holes so I can press my own studs but yet he still makes it sound as if I am going to have to use extended lugs.
He then asked for the lug size I am going to be using so he can drill to that size but I would be using the same as my stock size,..12x1.5mm which I already gave him. Would I not? Do I still need longer studs to be pressed into the spacer to compensate for the thickness of the spacer?
Than I have this site with a system to get the info they need on what you want. It seems they consider spacers with 5 holes and 5 pressed studs of the same bolt pattern to be adapters rather then spacers.
http://www.motorsport-tech.com/
What is what!?
Im more so on the same page as your explanation of this matter.
Many race organizations require several extra threads to be visible through an open ended lug nut to pass tech. On the other hand many wheels (cough RSs) require shorter studs for their center caps to go on.
